1988 camaro rs 2.8 v6 overheating
Old Apr 13, 2012 | 10:54 PM
cbadboyz14's Avatar
Car: 1988 camaro rs
Engine: 2.8 v6
Transmission: auto
Axle/Gears: stock
my problem is that my camaro is overheating my air damn is brand new, rad,new 16' fan two of them 180degree thermostat .it runs good in the cold weather when it get like 70 degrees out it starts over heating all city driving i dont understand why it would be overheat aslo i forgot to mention brand new water pump
Old Apr 13, 2012 | 11:46 PM
cbadboyz14's Avatar
Car: 1988 camaro rs
Engine: 2.8 v6
Transmission: auto
Axle/Gears: stock
Re: 1988 camaro rs 2.8 v6 overheating
please can someone help me find out whats wrong
Old Apr 14, 2012 | 12:33 AM
armos's Avatar
Have you checked that the fans are running? If you have AC, turning that on should immediately make the fans run. Of course, that doesn't guarantee that the temperature switch is working, the only way to check that is to let it get hot.
Are you losing coolant?
Old Apr 14, 2012 | 01:07 AM
cbadboyz14's Avatar
Car: 1988 camaro rs
Engine: 2.8 v6
Transmission: auto
Axle/Gears: stock
i have aftermarket gauge dont have a/c fans are defently working and im not losing any coolant
Old Apr 14, 2012 | 01:08 AM
cbadboyz14's Avatar
Car: 1988 camaro rs
Engine: 2.8 v6
Transmission: auto
Axle/Gears: stock
the only thing is that i didnt try is the timing.because some time i do get a backfire out of the intake
Old Apr 14, 2012 | 01:10 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Could be your temp sensor, is it boiling over? are you loosing fluid? What does your temperature control read in the dash? Are you going by the gauge?
Old Apr 14, 2012 | 01:13 AM
cbadboyz14's Avatar
Car: 1988 camaro rs
Engine: 2.8 v6
Transmission: auto
Axle/Gears: stock
i have a glow shift temp gauge with a coolant temp adapter in the top hose .like the temp will hold for a little bit at 200 then creep up to 240 it does boil over and it not loosing any coolant
Old Apr 14, 2012 | 01:15 AM
Engine: MPFI
Hows the fluid look in the Radiator? Is it boiling in the coolant tank?
Old Apr 14, 2012 | 01:17 AM
cbadboyz14's Avatar
Car: 1988 camaro rs
Engine: 2.8 v6
Transmission: auto
Axle/Gears: stock
green i also added water wetter to itto see if that would help it. it did for couple days then started overheating i still think it may be the timing the guy i bought it from said he mess with it trying to get it to make it sound like it was cammed lol
Old Apr 14, 2012 | 01:24 AM
Engine: MPFI
I'm not much of a mechanic, I wish I were and could help you more. Sounds like it could be the timing. I know the basics, but get most of my work done by a mechanic.
I know my 2.8 V6 over heated but once I flushed the rad and got a airdam the problem solved. Hope you get it fixed soon. Best wishes.
Old Apr 14, 2012 | 01:30 AM
cbadboyz14's Avatar
Car: 1988 camaro rs
Engine: 2.8 v6
Transmission: auto
Axle/Gears: stock
thanks man i know basic stuff too but ill doo my best to try to figure this out
Old Apr 14, 2012 | 08:53 PM
cbadboyz14's Avatar
Car: 1988 camaro rs
Engine: 2.8 v6
Transmission: auto
Axle/Gears: stock
i did the timing to day set it to 12 rans alot alot better but is still overheating
Old Apr 14, 2012 | 09:10 PM
Engine: MPFI
There is a guy in here that knows these motors inside and out, I will try and find him and add his name to thread. Maybe he could answer some of your questions. His Member name is Maverick H1L, he answers alot of questions about these motors.
Old Apr 14, 2012 | 09:30 PM
cbadboyz14's Avatar
Car: 1988 camaro rs
Engine: 2.8 v6
Transmission: auto
Axle/Gears: stock
thank
you
Old Apr 14, 2012 | 10:06 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
yes PM dan, he can help you before anyone else can, hes an amazing mechanic and guy!!
Old Apr 14, 2012 | 11:06 PM
cbadboyz14's Avatar
Car: 1988 camaro rs
Engine: 2.8 v6
Transmission: auto
Axle/Gears: stock
what is his screen name
Old Apr 15, 2012 | 12:21 AM
cbadboyz14's Avatar
Car: 1988 camaro rs
Engine: 2.8 v6
Transmission: auto
Axle/Gears: stock
i forgot to mention that i put in a reman water pump would that do it its also boiling coolant in the overflow tank
Old Apr 15, 2012 | 07:38 AM
Engine: L31 350
Wait did you get the correct flowing water pump?
Old Apr 15, 2012 | 08:24 AM
ex-x-fire's Avatar
Ok, when is it overheating, going down the road or at idle?
Old Apr 15, 2012 | 01:03 PM
cbadboyz14's Avatar
Car: 1988 camaro rs
Engine: 2.8 v6
Transmission: auto
Axle/Gears: stock
idk i got it at autozone
Old Apr 15, 2012 | 01:29 PM
Engine: L31 350
I bet you have the wrong directionally water pump and it's spinning the wrong way.
Old Apr 15, 2012 | 02:35 PM
ex-x-fire's Avatar
The pulley bolt pattern on those are usually different, plus if you gave them the correct year they should have gotten the right one. Do you know the part #?
Old Apr 15, 2012 | 03:38 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Um, Haynes has a nice pic of the water pump on a v-belt car and the pulley still has 4 bolts.
Definitely need to make sure the W/P is designed to go COUNTER-clockwise. I don't have the P/N on the pump I bought a couple years ago (only to find out the belt noise was the tensioner pulley going out) handy to compare. And yes, wrong parts DO come in the right boxes (those were some expensive exhaust clamps I took back to NAPA because some idiot at the warehouse or wherever decided to put 2 1/2" clamps in the 2 1/4" boxes ).
If you're not losing coolant, have an air dam, have a cooler thermostat (stock is 195), and the fan is working, that leaves either clogged ports in the head gaskets, clogged radiator, or backwards water pump. Or a combination of all 3. Try a system flush first, after you make sure they gave you the pump you're supposed to have.
Old Apr 15, 2012 | 03:51 PM
Engine: L31 350
^ listen to him lol
Old Apr 15, 2012 | 04:00 PM
ex-x-fire's Avatar
The bolt pattern still has 4 holes but not in the same location.
He most likely has a blown head gasket.
Old Apr 15, 2012 | 04:02 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Doubtful... Pump snout looks exactly the same. And he's NOT losing coolant.
Old Apr 15, 2012 | 04:44 PM
ex-x-fire's Avatar
If he has the wrong pump, he'd have either an extra bolt hole or a bolt with no place to go. Plus the serp w/p have a cast boss for the p/s pump bracket. Timing cover coolant passages are different too.
Attached Thumbnails 1988 camaro rs 2.8 v6 overheating-41izmgxujml__sl500_aa300_.jpg   1988 camaro rs 2.8 v6 overheating-41xc-c19eil__sl500_aa300_.jpg
Old Apr 16, 2012 | 09:06 PM
cbadboyz14's Avatar
Car: 1988 camaro rs
Engine: 2.8 v6
Transmission: auto
Axle/Gears: stock
ok found the problem it was the thermostat the one in it was made by hypertech 180 with failsafe dont buy them the bore where the thermostat sits in since it had a failsafe it wouldnt allow in to open because the fact the hole wasnt deep enough to let it open up but its fixed now with a 192f thermostat runs like a champ never goes pass 200 now
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
IROCZ28KevinZ
Jun 10, 2003 11:18 PM
BigE
Sep 23, 2002 05:38 PM
Camrs89
Jun 20, 2002 05:00 PM
