Fixed one problem...Now another
Old Jun 4, 2002 | 09:27 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Ok, I fixed the idle problem on my camaro, now I have a overheating problem. I installed a Griffin radiator in my car, but the temp will still rise to 210 (I shut if off b/c of the high compression engine) I am running a fan on the pulley (stock fan) and the guy that built my engine made some by-pass thing with my themostat. Suppose to cool better than a thermostat. But I am worried. I know its hot out but I can go more than 10 miles without the temp getting high. Any ideas? Thanks
Old Jun 4, 2002 | 10:08 PM
Jester's Avatar
I dunno what your engine builder did to bypass the thermostat, but undo it. Thermostats are a good thing.
Old Jun 4, 2002 | 11:32 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
def undo the bypass..........thermos are a godsend
Old Jun 5, 2002 | 12:38 AM
Morley's Avatar
Thermostats and radiator caps keep the system under pressure which prevents the coolant/water from boiling and makes the system cool better, you need a thermostat.
~M~
Old Jun 5, 2002 | 01:44 AM
blk91z28's Avatar
Do you have a fan shroud?? I also have to say put a thermostat back in.
Old Jun 5, 2002 | 06:49 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
210* does not seem that uncommon...does the temp continue to climb? Or does it stop there...I agree with everyone else...Mods are good some places, others, stick to the time tested systems.
Old Jun 6, 2002 | 12:07 AM
HrdRockA4305's Avatar
Yeah, I said 1. Install a freakin thermo, the car is driven on the street not the track. 2. There is no fan shroud.
I think we've figured out the problems here guys. But seriously, we do need to keep this motor cool cause it has like 11:1 or so compression and iron heads and burns pump gas.
Old Jun 6, 2002 | 05:07 AM
Engine: 406
I think the shroud will solve your cooling problem,,,,the fan needs to set fully into the shroud..I,m running mechanical and my temp has never seen above 200*. Even in traffic at 95* Iowa style....wich euqals about 110* anywhere else...
Old Jun 6, 2002 | 04:10 PM
32789RS's Avatar
I agree I would get a fan shroud, this should fix your cooling problem, the next thing I would do is un-bypass the thermostat, it's there for a reason.
Old Jun 6, 2002 | 09:57 PM
Camrs89's Avatar
I think i need a fan shroud. I need to either "make" one or find one that will fit my radiator. I was told not to let the temp go above 210 because of 11.5:1 compression.
Old Jun 6, 2002 | 10:05 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yep, I didn't run a fan shroud last summer with a 160* stat, in traffic in 100* weather it would get up to 230* not good. So I got a GM fan shroud top and bottom for $90, and in the same weather traffic, with a 180* doesn't go above 210*.
Old Jun 7, 2002 | 05:54 AM
Engine: 406
check the local junkyards..I got mine..upper and lower with the radiator for $35.00. We have a yard here that crushes cars real quick. They let you have as much as you can carry out for $35.
Should have seen me carry out my old 700r4...... Its funny just to watch the guys tear door panels and such off the cars, load them up with as much, usually more than they can handle. Its funny...walk 10ft pick up what ya drop...10 more ft...you get the picture, looks like the ending of a dramatic marathon...LMAO.....
Old Jun 7, 2002 | 04:40 PM
Camrs89's Avatar
Yeah, i dont know, cause my radiator is one my engine builder has. A universal one so I dont know if I can fit a cover of it.
Old Jun 18, 2002 | 12:28 AM
Man I hear that... Our town is a little under an hour and a half from you're state. I've heard it in a chain letter "If you have ever used the heat and the air conditioning in your car in the same day before..." I'll assume this applies not just to Illinois.
Old Jun 19, 2002 | 11:15 PM
Camrs89's Avatar
or seasons for illinois almost winter, winter, still winter, road construction lol
Old Jun 20, 2002 | 12:34 AM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
The weather sounds like ohio too. winter, winter more winter and construction. You have to love the weather in the north east states lol
Old Jun 20, 2002 | 05:00 PM
Engine: 406
The nice thing about Iowa is if you dont like the weather...justwait 10 minutes it will change..
Bubbajones_ya
Oct 25, 2015 08:01 PM
Giocio
Oct 1, 2015 12:20 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
