Heater hose to -X AN hose
Old Apr 26, 2012 | 10:55 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
It's about time to replace my heater hoses! I've been thinking for a while about changing my heater hoses out to to an AN system. It would look much cleaner and a little easier to work with. I've been searching and found that the heater hoses are a 5/8 and 3/4 so I believe I will need -10 and -12 AN lines and fittings. Does this sound correct and has anybody done this? Just wondering before I spend the cash and have some odd problem or order the wrong pieces.
Old Apr 26, 2012 | 11:00 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Heater hose to -X AN hose
Those sizes would be right. If you're only interested in the appearance, just get some sleeving and some decorative hose clamps. It'd be a lot cheaper and easier to work with.
Old Apr 26, 2012 | 11:25 AM
Tibo's Avatar
Car: 1991 Z28 Vert
I agree with you on the price, and I already have a complete hose sleeve kit, uninstalled. Appearance will be half of the reason, Preference is the other. With the AN I can utilize 45 and 90* bends without worrying about kinks.
Old Apr 26, 2012 | 12:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Those would be some seriously expensive bends. I'd just put an anti-collapse spring around it wherever I wanted it to bend.
Old Apr 27, 2012 | 11:48 AM
Tibo's Avatar
Car: 1991 Z28 Vert
I went ahead and priced it, I can get the AN 45* bends and 1/2 NPT to -10/12 AN off of ebay for 10 and 5 respectively, The braided line I can get from Summit, 3 feet for 20-24. Not as bad as I thought it might be. I have some other projects still to finish (like finishing MegaSquirt) but I'll post pics in a month or two when its on.
Old Apr 30, 2012 | 08:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
one line is 5/8od the other is 3/4 od. I did this conversion
I don't have ac, with ac it may be different, but I used 2 90 dregee adapters both to 1/2 female npt.and soldered them on at about a 45 degre angle.to.the passengerside, they both kinda straddle the threaded ground post on the corner of the heater box coming off the firewall. From there, plumb as needed with 10an line, don't bother with 12an, not needed.
Fittings off these adapters are 45 degree, fits perfectly with a heater only box. I have posted pics of this before
Old May 9, 2012 | 06:22 PM
Tibo's Avatar
Car: 1991 Z28 Vert
I found your posts, which were useful. I decided to go ahead and use 10 and 12. I couldn't find the correct fitings and I called a lot of places. But I think my total for all the line and fittings was about 75. I'll post pics in a month or so when I get to an installation.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
shanelique22
Sep 24, 2015 06:30 PM
Stryker412
Sep 20, 2015 06:59 PM
st.evel07
Sep 19, 2015 09:24 PM
