A/C High pressure switch
Old Apr 26, 2012 | 03:52 PM
sylentnite's Avatar
Car: 1989 Trans AM
Engine: 383
One of the prongs on my high pressure switch located on the back of the A/C compressor is broken, My question is would I be able to replace the switch without losing freeon? The new switch came with o-rings and I wasn't for sure if I removed it wheather or not I'd lose my a/c charge...Thanks!
Old Apr 26, 2012 | 03:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: A/C High pressure switch
You have to evacuate before you can change the switch.
Old Apr 26, 2012 | 03:57 PM
sylentnite's Avatar
Car: 1989 Trans AM
Engine: 383
Ahh..OK...I was kind of thinking that, but wanted to make sure..Thanks!
Old Apr 27, 2012 | 12:15 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
side note: all other switches on a/c system can be removed and replaced without evacuating the system. high pressure switch is the only one that requires evacuation to replace.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
jackhammer
Aug 15, 2015 10:04 PM
