Green wire from electric fan, where does it go???
Car: 91 camaro rs
Engine: 305 (350 vortec in dec.)
Transmission: Wc-T5
Axle/Gears: 3.08 (3.42 in dec.)
I have a 91 camaro 305 tbi.... Looking at the schematics now.... It says green wire with white stripe.... My fan has dual fans from the factory.
2-black
2-yellow
1-solid green
Where is the green wire supposed to go? That's all I need to know, the other wires are hooked up, the green is just hanging. Thanks
2-black
2-yellow
1-solid green
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Green wire from electric fan, where does it go???
Where are those wires attached ? A more detailed description of what and where you have would help
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
So if they're hooked up...the black and yellow should correspond to your fan's, positive and negative wires right?
The green wire will should be the one that runs over to the fan switch on the passenger side head between the #6 and #8 cylinders and tells the second fan to turn on at a specific temp. The first fan being controlled by the ECM.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
It's highly likely some of the wire colors are different since someone has put in dual fans in what was originally a single fan car. Where are the fan relays located?
eightsixseven
Dec 16, 2024 01:50 PM
