Changing Water Pump and T-Stat
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
I am changing the water pump and t-stat tomorrow. Got a 180 degree t-stat, and a performance water pump from advanced. How do I need to flush the radiator out and what is the correct ration of coolant-water for these cars. I have a 305 TPI. Thanks
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Changing Water Pump and T-Stat
50-50 coolant/water. I buy the concentrated coolant, put 2 gallons in, then fill the jugs with water and pour that in. Then just top it off with the rest. Unless you run into freezing temps, you'll be fine with a higher water concentration which will actually cool better.
For the flush, do a search on the site, that should find what you're looking for.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Dialed_In
Aug 20, 2015 01:45 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
