Cooling fan question.
Old May 2, 2012 | 04:44 PM
806camaro's Avatar
Car: 1990 IROC
I have a 1990 camaro IROC. Everything is stock. My question is, shouldn't both electric fans be on if the AC is running? Only the drivers side fan kicks on. I read other threads on here, if AC is on both fans should be running, this true? Do I have a broken fan?
Old May 2, 2012 | 08:16 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Re: Cooling fan question.
yes. Back probe the 2nd fan with a volt meter and see if it sees voltage. If yes, bad fan motor. If not, could be wiring, relay.
Old May 11, 2012 | 03:20 AM
TrueIroc's Avatar
Car: 1989 IROC-Z 100% Original
Engine: 5.0 TPI
Axle/Gears: 3.08
Hey 806Camaro,
Does your 2nd fan ever turn on? Like even when it gets hot??
I have a '89 Iroc, 305, T-5 all stock. I'm having the same trouble as you, my 2nd fan (right side) never comes on. But I never use my A/C cause it needs a new compressor. Once my car gets up to 235 deg, only the left fan comes on to cool the motor. I never saw the right one come on, and I want it too. I was thinking my problem could be the fan itself or a bad relay. I don't know if theres 2 relays for these fans. Did you fix your problem?
Old May 11, 2012 | 03:54 PM
806camaro's Avatar
Car: 1990 IROC
Originally Posted by TrueIroc
Hey 806Camaro,
No the second fan never kicks on, I have read on here that it only comes on when the AC is on. I don't run my AC in fear of over heating.
Old May 13, 2012 | 08:18 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
This should answer all of your questions
https://www.thirdgen.org/forums/cool...ans-arent.html
Old May 16, 2012 | 01:47 AM
TrueIroc's Avatar
Engine: 5.0 TPI
Axle/Gears: 3.08
Thanks... Good link!
So in order to get my passenger fan running again, I need to fix my A/C?
Old May 16, 2012 | 12:28 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Not necessarily, first put 12 volts to the fan to see if it even works, then go back and ground the green with white stripe wire at the relay with key on to test relay. If that works check for possible wiring breaks by grounding the same wire at the fan switch with key also on, etc, etc. Basically start at the fan and go backwards until you find the fault
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
z28joe2
Sep 28, 2015 05:54 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
