1989 Dual fan issue
Car: 1989 IROC-Z 100% Original
Engine: 5.0 TPI
Axle/Gears: 3.08
1989 Dual fan issue
I have a '89 Iroc with dual fans. I've never seen the right fan come on. I only see the left fan come on, and it only comes on at a high temp (235 deg). Too me thats a bit high, I don't want to blow any head gaskets. Once it comes on it takes a few mins to cool the motor down and by then the temp is over 245 deg, before the motor actually starts to cool itself down. Why doesn't my right fan come on? Is it shot??
1.I'd like to have that 2nd fan come on... Is the right fan shot and I have to buy a new one, or is it something else??
2.I'd like to have the left fan come on sooner then 235 deg, by then its too hot. Is there a way to make the fans come on sooner?
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Re: 1989 Dual fan issue
Same prob on my 89 Formula.
1. Is the pax fan good? Find out by key on engine off and grounding the wire going to the fan switch (in the head b/w #6 & #8 cyl. Hard to get to. Above the starter, pull the wire from below. I ran a temp wire from there straight to the neg battery term. When grounded the relay near the charcoal canister will click and power up the fan. If fan does not come on does it get 12v on the click? If it gets 12V then the fan is bad like mine was.
Let us know.
Let us know.
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
From my understanding the second fan is only there for back up in case the first fan fails and your car reaches above 220. Thats what I read somewhere?
Engine: 4++,350 & 305 CIs
Either 239* or turning the A/C on will kick on the 2nd fan. (nless something is wrong)
TTAs used a lil bit cooler 2nd fan switch 229* (I think)
Hypertech makes 2 switches that are way colder and they are used for 180* or 160* T-stats
Aw TTOP that's wacky. My *driver* fan comes on when I turn on the AC. I just replaced the pax fan. Need to do some driving and watch it. Got a new rad and water pump in there. Will report back..Thx
I have run into that before. Here is the diagram for ya.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
It's probably too cold in Massachusetts for the passenger fan to kick on. Even with the air conditioning turned on. I just wrote up a huge post about this.
Throw a 200/185 fan switch in there. Cheap at $40. And even if that's not the problem, it's still a good thing to have.
I thought both fans are suppose to run together and not a a certain temperature. I noticed that my 2nd fan is not on and i vaguely remember it being on. i don't see it hitting on at 220 either? can someone assist?
Reread the whole thread. 2nd fan comes on at 239 or so
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
with that wiring diagram what connections are going through the connector going back to the main harness. i am trying to rewire my duel fan setup and am getting confused with what wires go where.
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
i guess reason im confused is because shouldnt there be 2 relays 1 for each fan so then wouldnt there be more then just 4 wires at the connector
I saw that orig part of thread but I am thinking the fans were wired to come on together. I will see if I can get a pic of them. I see a wire connecting both together with a bud connector. That is why I am thinking they both run and keep the car running very cool.
your thoughts?
Thanks for the info.
your thoughts?
your thoughts?
I take that back, the grounds from the fans may be connected and the main power wires to the relays may be connected.
So if this is the case where the grounds were wired together to have run at same time, where would you start first to check why the 2nd fan is not running?
Unplug fan, Make a harness and give the fan 12 volts and ground from the batt.
fan run? yes? no? work back from there.
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Yea I looked at the manual and post #6 and that answers zero questions. Both wiring diagrams show two different wiring setups. I have brand new main harness connector wire and relay connector also the two sets of wires coming from the fans. Do I connect both fans together to the relay or is it wired different
The (factory) service manual is all you need. It answers your questions and tells you where everything is located.
Each fan has its own relay but the relays have a single heavy power wire feeding the relays.
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
In the service manual it shows two separate switch sources but the connector only has 5 wires and any aftermarket stock replacement wiring has only one relay and has the two fans wired together as far as I can tell
In your factory service manual there is a section called "component location" or something like that. It will tell you where everything is. Heck, it may be on google also.
This looks like the camaro setup because it has the fan jumper connector at the top middle.
This is 4 a single fan but you need to finde one of these 4 a dual fan. It tells you where your relays and things are.
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Hmmm thanks for the diagram ill have to see how this is going to work. For some reason to me it looks like I might have the wrong wiring harness for the duel fan setup unless the 89 has a weird setup
Roblyons
Interior Parts Wanted
Aug 30, 2015 12:07 PM
