Coolant temp switch
Old Jun 4, 2012 | 08:54 AM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
Coolant temp switch
I have done some searching, and haven't be able to find. What driveablility issues happen if this sensor is not working. I didn't change the sensor before the engine swap, Due to thinking it was the AC fan switch. And just to clarify what I am assuming is the CTS is in the water neck / thermostat housing. The check engine light isn't coming on, Would it? What issues will I see if this isn't working?
Thanks John
Old Jun 6, 2012 | 09:26 AM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: Coolant temp switch
That one gives the computer info on whether the engine is warmed up or not. I would imagine if it isn't working your computer would think the engine is cold all the time so your gas mileage would go down a bit.
Old Jun 6, 2012 | 03:48 PM
spud's Avatar
Engine: 400 & 355
Sounds feasable, I sure hope it helps. The last check it was getting 10.8mpg. I have changed the O2 and the CTS.
89 formula TPI
Oct 6, 2015 08:40 PM
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
86IROC112
Sep 11, 2015 04:04 PM
85Special
Sep 3, 2015 04:21 PM
