Ac pressures
Old Jun 8, 2012 | 03:15 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Ac pressures
Does anyone know the exact pressures are needed in the ac? Right now I have my low side set at 32.
Old Jun 8, 2012 | 06:29 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: Ac pressures
I think that is right.
Old Jun 8, 2012 | 06:34 PM
Engine: L31 350
Re: Ac pressures
High side? I'm running r12
Old Jun 10, 2012 | 02:04 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Ac pressures
Should be around 25 psi when cycling off.....If it's running at 32 psi just idling in the driveway, then you're probably OK.
db057
Jan 10, 2020 08:55 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Stryker412
Sep 20, 2015 06:59 PM
CatmanFS
Sep 19, 2015 09:00 AM
TBRays98
Sep 6, 2015 05:05 PM
