CTS
Old Jun 11, 2012 | 09:05 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
Axle/Gears: soon 4th gen 3.23 w/ Posi
CTS
ok, so I swapped my gauge cluster from the 85 mph w/ dummy lights to the 115 mph with actual gauges. I replace the coolant temp sensor with one for the gauge and not light. well when I'm driving the sensor will slowly work it's way to topping out at 260 (or atleast that's what I think it is.)
My question is, should I be concerned? is it overheating by being that high?
if it helps any, I have the stock mechanical fan on my car.
Old Jun 12, 2012 | 12:29 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: CTS
sure sounds like something is "off" with the guage
(such as wrong sender) Does car smell or act "hot"
when gauge is at 260? If the high temp readings only
occur at higher speeds,check that the air dam is in
place-it is needed for radiator airflow at higher speeds
as clutch fans freewheel at higher RPM and electric fans
generally don't pull enough air to cool at higher speeds
without the airdam.
specialized
Jun 18, 2022 09:26 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
GTAman
Sep 21, 2015 09:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
