EGR and overheating
Old Jul 22, 2012 | 11:00 AM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
EGR and overheating
Does anyone know if a bad EGR valve causes freekish heating issues? I have been having some wierd heating reading on my gauge and prettymuch replaced my entire cooling system to include a new temp gauge sensor. I seen SES light pop on and it read code 32 so I swaped my EGR valve out and it seemed to fix the issue.
Old Jul 22, 2012 | 12:07 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: EGR and overheating
Did you notice any "pinging"under low rpm/moderate load conditions?faulty
EGR can cause pinging that will increase coolant temp.
Old Jul 22, 2012 | 12:29 PM
Car: 92 Camaro RS
Engine: 305 TBI
Im not sure what you mean by "pinging" but after the new EGR the performace of the car seemed night and day... I had no idea how important the EGR valve is. I took the car out 2-3 more times after to check the hotter than usual cooling issue and it seems perfect... I think if I still ran my stock fan switch and stat with this issue I would have blown an engine before I figured out problem was a EGR valve.
-Actually I do remember I did sort of notice a odd pinging noise once in a while at lower rpm
sheachopper
Jul 31, 2019 11:27 AM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
