Installed Gauge temp switch on 2.8 now electric fan does not engage
Car: 1985 Camaro Sport coupe project
Engine: 2.8 mild cam
Transmission: T$ V6 5speed manual 4.04 first
Axle/Gears: 3.42 Limited Slip
Ok story goes, swapped in a Cluster with tach and Gauge instead of idiot lights. Switched out the the TEmp sender from idiot light, to one for a guage. Single wire on both of them. Now the temp guage goes up all the way to 125c, yeh Im canadian which is 257f well above the ecm's limit of 220f. Electric fan does not come on, Relay is ok.
So my question is, does anyone know if the the Idiot light sender unit, just sends a On / Off pulse to the ECM to tell it to turn the fan on, then the ECM turns the fan on, and if switching to a Guage sender instead fouls up the readings .
Note read as many post as I could,
Power at Brn/tan showing 12 volts
Grounding sender singer wire pegs Guage at max temp, no fan engaged
Cutting and grounding Green white ECM wire, engages the fan manually
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Installed Gauge temp switch on 2.8 now electric fan does not engage
It is the CTS that gives the computer coolant temps ,the gauge sender has nothing to do with it
LMAO ok im the village idiot today. I was not aware that the there was a CTS sensor on the engine till you mentioned it, and after some digging I found it under the Throttle body. My brother built the engine about 10 years ago, and we finally got around to getting it running.
I found the sensor, and luckly the Parts store gave me the wrong sender earlier in the week, so Ill change it out when the engine cools down
Ghettobird52
Jul 5, 2024 11:18 PM
86IROC112
Aug 17, 2015 02:00 PM
TA8487
Aug 16, 2015 12:21 PM
