Oil pressure running higher at idle?
Old Aug 1, 2012 | 06:56 AM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
Oil pressure use to run at the first yellow mark for the longest time after car was warmed up, now it runs at 25-30 psi at idle warmed up.. is this normal? and could someone explain the change is psi? (I use the same weight oil I have been for 3 years (10w30)
Old Aug 1, 2012 | 07:10 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Oil pressure running higher at idle?
You might want to check your oil pressure with a different gauge. Seems to me maybe your sending unit or the gauge you are reading are not working right.
Old Aug 1, 2012 | 06:05 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
25 or 30 is not so bad. It is recommended that you have at least 10lbs for every 1000 RPM you're running. Does it go up as the revs go up as you drive? Hotter weather and old oil can cause a slight drop in pressure sometimes
MustangBeater20
Oct 29, 2022 09:20 PM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
wayshegoes
Aug 17, 2015 12:00 PM
ChevyZ71
Aug 13, 2015 07:30 AM
