Coolant Hoses and there part Numbers??
Old Aug 5, 2012 | 11:12 AM
snipzors's Avatar
Car: 87 iroc z
Engine: 5.0 TPI
Transmission: t5
Axle/Gears: stock
Hey guys probably a stupid question, but last night one of my coolant hoses decided to split wide open on me....
87 iroc 305
its the hose that comes out just underneath the throttle body, does a u turn back into the block..
is there a specific molded hose i can purchase or can i just cut some heater hose to length?? just worried about the bend.
thanks
Old Aug 5, 2012 | 11:33 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Coolant Hoses and there part Numbers??
GOODYEAR Part # 63251 ,GATES Part # 18777, ACDELCO Part # 14097S
Old Aug 5, 2012 | 11:47 AM
snipzors's Avatar
Car: 87 iroc z
Engine: 5.0 TPI
Transmission: t5
Axle/Gears: stock
thanks for the quick info, unfortunately nobody in my crap city carries it or can get it in...... However the guy just told me alot of people bypass this hose, as its not needed if you are in a warm climate, or in my case only drive the vehicle in the summer.. Is there any truth to this and if so is there a sticky on this bypass procedure??
Old Aug 5, 2012 | 11:49 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Yup, simple. There is info here about this do a quick search.
Old Aug 5, 2012 | 12:01 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
autozone has high miler hoses that are supposed to last a lot longer than regular hoses. I have samco hoses on my zr1 and they are essentially racing hoses. Don't know if they make samco for 3rd gens but I hope they do.
Old Aug 5, 2012 | 12:25 PM
snipzors's Avatar
Car: 87 iroc z
Engine: 5.0 TPI
Transmission: t5
Axle/Gears: stock
ok so i just researched and i believe i understand what needs to be done, however i just realized i dont have a heater control valve/diverter, it appears before i had purchased the car this was replaced with a connector and just another piece of hose going into the left side under the TB,.... is this a necessary piece or can i now go from one to the other... and what is the purpose of the diverter
Old Aug 5, 2012 | 12:38 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/coolantbypass
https://www.thirdgen.org/forums/tpi/...nt-bypass.html
https://www.thirdgen.org/forums/tpi/...at-1988-a.html
https://www.thirdgen.org/forums/tpi/...nt-bypass.html[/QUOTE]
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
