Replace original '89 low mileage hoses, or not?
Car: 1989 Formula
Engine: 305 LB9 TPI
Transmission: 700 R4
Axle/Gears: 2.73 Positrac
The system needs flushing and new antifreeze; I'm not sure when it was done last. But I'm undecided about replacing all the hoses. Yes, they're 23 years old but there's only 31,000 original miles on them, and the car.
They look and feel like new; and it's cool the heater hoses are date coded as well. But the date codes won't give me much satisfaction when I'm on the side of the road with a burst hose.
It's had a sheltered life--even the original tires have no weatherchecking on them.
What do you guys think?
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: Replace original '89 low mileage hoses, or not?
Depends on what your use will be. IMO if you are only going to carshows on weekends or out for cruise night, leave everything as it is. If any more than that, take the parts off and put them on the shelf. The same thing is true about the tires. You can't always tell a good tire from one about to fail because of age.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Car: 1989 Formula
Engine: 305 LB9 TPI
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
NBrehm
Aug 25, 2015 11:49 PM
NBrehm
Aug 5, 2015 07:57 PM
