T-stat and fan activation
Old Aug 16, 2012 | 05:58 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Sorry to beat a dead horse!
I recall a while back there was a thread where someone mentioned the
T-stat opens vs fan activates for optimal cooling.
T-stat opens before fan comes on
Or
Fan comes on before T-stat opens?
Thanks for any help!!
Old Aug 16, 2012 | 09:10 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Re: T-stat and fan activation
T-stat first, how is cooling a cold radiator gonna do any good. Now thats beating a dead horse.
Old Aug 16, 2012 | 11:19 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I run a 195 year-round.
It's 120deg. F here lately.
Combustion makes heat and kinetic energy to the crank. Trying to run the engine cooler slurps energy from the combustion chamber.
Fan temp on some apps are in the 220 range. Keep in mind, that's not boiling in a closed, pressurized (radiator cap stock in a third gen is 15psi) system.
Thermostats don't cool, they set a minimum temp.
Airflow and fans do help the radiator shed heat; if the turn-on temp were lower than the thermostat, they would potentially run endlessly which is pointless.
Old Aug 19, 2012 | 10:51 PM
Car: '87 Camaro
Thanks for the replies // info!!
Old Aug 20, 2012 | 11:54 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
t stat opens before fan comes on- if the cooling system is in good shape, the fans will never come on if the car is moving faster than about 20mph unless you turn the AC on.
i have a 195 t stat in my car, with a switch that turns the fan on at 220 and off at 210.. works perfect..
Old Aug 30, 2012 | 09:18 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Running the fans before the thermostat opens doesn't do much but cool the radiator (that's not circulating any coolant). So it's a waste of energy and fan motor life to run a 166° radiator turn on point on a car with a 195° thermostat.
Of course the whole thing is moot if you live in a hot climate anyways, since turning on the A/C will generally turn on the fans even though the engine is still cold.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
