Blend Door Issue
Old Aug 25, 2012 | 11:29 PM
Rescue Wagon's Avatar
Blend Door Issue
So the piece that attaches the blend door to the controls in the center console has broken off. Now when you slide the heat/cool control back and forth the cable moves, but the cable is no longer attached to the blend door. The current option has been a set of pliers, but you can't adjust it while you’re driving.
Now the million dollar question is how can you fix this issue?
Thanks.
Old Aug 26, 2012 | 05:11 AM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
Re: Blend Door Issue
Rig it or visit ur local JY for a replacement door
Old Aug 26, 2012 | 12:50 PM
So, Do I need the entire box ?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
