Heater Core Bypass...plz help...
Old Aug 27, 2012 | 01:36 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So I got a 84 Z28 LG4 engine, and all of a sudden when i parked i hear sizzling under the hood and for some reason the hose coming form the heater hose which goes into the engine block(not into the water pump) is spewing out boiling radiator fluid. I know I got a bad heater core, but could that be why it did that? and regardless whether its because of that or not how do I bypass it...do I just connect the hose together?thanks!
Old Aug 27, 2012 | 01:52 PM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
Re: Heater Core Bypass...plz help...
follow the hose to the water pump. put a plug there. follow the other hose the the intake. put a plug there. done.
you should just fix the heater core if that is your problem. better it fixed than put a band aid on it
Old Aug 27, 2012 | 01:53 PM
calgutie's Avatar
Car: 1984 Z28
well ima plan to fix it later on but cant i just connect both of the hoses together so that the fluid circulates?
ndndndnd
Sep 28, 2015 08:00 AM
Formula8r89
Sep 22, 2015 04:24 PM
