hard wired fan wont kick on now
Old Sep 7, 2012 | 09:31 AM
91camaroRS3.1's Avatar
Car: 86 T/A
Engine: 305c.i. carbed, highrise, compcam
Axle/Gears: idk..
so when i got my 86 t/a the elctric fan was "hardwired" to run when the key was turned on. i dont know much about it except that there are 3 black wires at the firewall on the driver side that he had connected together. and up to this point it has worked, when the key is on, the fan is running...only one prob was when the wire came unplugged form the fan itself. but that was no biggy, after i plugged it back in it worked fine...now its not working? the 3 black wires are still connected and the fan is plugged in? any ideas? the fan is a little wobbely but spins freely, not hung up or anything.
Old Sep 10, 2012 | 03:55 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Welcome To The Fan Club
The best way to fix the problem is to restore the fan circuit to its original configuration, however in the mean time apply 12 volts directly to the fan with a couple of jumper wires from the battery.
If it still won’t run the fan motor is defective.
If it does run remove the jumpers and make sure the fan is grounded.
If it is you have an open circuit from the hot in run circuit that was energizing the relay or the direct feed.
You didn’t say if a relay is (still) being used to run the fan.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
Old Sep 24, 2012 | 11:42 AM
Car: 86 T/A
Axle/Gears: idk..
Re: hard wired fan wont kick on now
found out when the kid before me swaped the motor he COMPLEATLY hacked up the wiring....no i gotta go through it and find what goes to what, what goes to nothing and what is burnt/grounding out.....here goes some fun
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
db057
Aug 22, 2015 08:17 PM
