Lower Air Dam
Old Oct 6, 2012 | 09:36 PM
86F.BiRD's Avatar
Car: 1986 Pontiac Firebird Base
Engine: SBC 350
Transmission: Borg Warner T-5 World Class
Axle/Gears: 4th Gen Rear with 3.73s
Lower Air Dam
When i bought my 86 Firebird Base the lower air dam was all messed up and looked pretty bad hanging down under the car, so i took it off, not knowing that they were a key part to the cooling on 3rth gens. So doesn anyone know where i can get a replacement? Pics of your installed ones would be greatly appreciated. THANKS!
Old Oct 7, 2012 | 06:09 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Lower Air Dam
The air dam is actually comprised of several pieces. I assume you want the deflector that looks oh so nice and drags on everything making it sound like your ripping the nose off the car all the time. Here's one:
EDIT: oops, wrong years I'll look for another one.
EDIT2: This should be the right part. Better hurry, only 23 days to go.
http://www.ebay.com/itm/82-92-Camaro...613d81&vxp=mtr
Old Oct 8, 2012 | 03:27 PM
firefox7518's Avatar
Car: 1989 TransAm GTA
Engine: 350ci
Transmission: TH700
Axle/Gears: Stock 9-bolt
Re: Lower Air Dam
It's really easy to do it your self with some sheet metal. When I bought my GTA from a so called Pontiac doc it even didn't had a air dam. Finding such parts here in Switzerland is not easy and if yes they are damaged from the things AFREMONT mentioned :-)
I fabricated it that way
I used a lot of screws, even more than on the pic. Took it during install. Because it is metal i wanted to secure it enough so that it never could fall down and harm someone behind me. Plastic would be better but we have lots of speedbumbs and steep driveways where I hit the ground sometimes, but hey, I have to use the GTA because I can't use my Alfa 75 because it's too deep :-) Metal will last longer.... hopefully, hehe
Old Oct 8, 2012 | 03:42 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
Engine: 350 ATK Performance
Axle/Gears: Eaton 3.73
Re: Lower Air Dam
Old Oct 9, 2012 | 10:32 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Lower Air Dam
NOS on ebay; Item 290780012328
Old Oct 10, 2012 | 11:45 AM
torque_is_good's Avatar
Re: Lower Air Dam
they tend to still be on most 3rd gens in my local boneyard
Old Oct 10, 2012 | 12:10 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Lower Air Dam
You basically have 2 types. 1.) First design and it makes a complete "V" shape from fender to fender to 1 piece. It is pretty flexible. 2.) The revised 2nd design. It's 3 pieces a straight piece under the radiator and 2 side pieces.
http://www.hawksthirdgenparts.com/pr...Deflector.html
http://www.hawksthirdgenparts.com/pr...-Cooling).html
Different site with different pictures.
http://www.moderndaymuscle.com/exterior4?b=1
I think I still have the GM install sheet for the 3 piece one I can post it later if you want.
1992 Trans Am
May 10, 2023 07:19 PM
87iroctheo
Dec 4, 2016 11:47 AM
krisner89
Oct 10, 2015 06:03 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
