84 trams am coolant sensor issuse
Old Oct 20, 2012 | 09:00 AM
bypass-21's Avatar
Car: 1984 Trans Am
Engine: 305 cui
so after replacing my ported vacuum switch, my coolant sensor i was hoping that the codes on my comp would go away. the light does not go on but the computer reads codes. im worried that i switched the wrong sensor with the coolant sensor, i thought it was. in the thermostat housing in front of the carb, their bottoms looked right but the top (connector wise) was completely different (new one came with a connector)
i took pics of the one i took out, hopefully its where it bongs in the right spot
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
heres an old pic of where it was next to the ported vacuum switch
[IMG][/IMG]
thanks guys
Old Oct 20, 2012 | 09:58 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 84 trams am coolant sensor issuse
you changed the right one-that is the CTS for the ECM.I have heard the original style CTS with the concentric plug is no longer made,so replacements are all '85 up style and come with replacement plug.
Old Oct 20, 2012 | 10:26 AM
bypass-21's Avatar
Car: 1984 Trans Am
Engine: 305 cui
that's a relief, thanks. but why does the code still show, plus my temp gauge reads over 100 and the computer identifies it at life 60 or 70 degrees?
Old Oct 20, 2012 | 10:39 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
reset the ecm to clear the codes?
Old Oct 20, 2012 | 12:03 PM
bypass-21's Avatar
Car: 1984 Trans Am
Engine: 305 cui
i fixed the way it was reading the temp it was the computer, it was set at Celsius instead of Fahrenheit but returning to that, how do i reset the codes? i have no idea. my computer reader is an snap on with cards
Old Oct 20, 2012 | 12:10 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
you just disconnect the car battery for a couple min. and stored codes in the ECM will erase.
Old Oct 20, 2012 | 12:20 PM
naf's Avatar
naf
or disconnect the ecm power wire for a few seconds so you don't lose your radio station presets. it's a single wire coming from the pos batt terminal and running along the right inner fenderwell. should have a quick connect plug on it.
Old Oct 20, 2012 | 01:11 PM
bypass-21's Avatar
Car: 1984 Trans Am
Engine: 305 cui
worked like a charm, plugged the comp in after and it said no codes present
appreciate the help guys
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
BWilcox
Sep 20, 2015 12:19 PM
FormulasOnly
Sep 10, 2015 09:07 PM
