R4 to Sanden for Serpentine Systems
Old Feb 27, 2015 | 10:07 AM
  #51
gearhead141's Avatar
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Re: R4 to Sanden for Serpentine Systems
The TruckersAC website does have an FLX7 model (4868) that is universal with a single pulley. The price is reasonable too! That part of the equation I can figure out fairly easy. The bracket is the part I'm wondering about. The Sanden would be a great option if the original compressor dies. I don't feel the need to re-invent the wheel; if someone has already done this reliably, I'm content to pursue that avenue. I was hoping that someone who had might chime in.
Old Mar 3, 2015 | 10:16 PM
  #52
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Done for now... still have to connect/run wiring...
Attached Thumbnails R4 to Sanden for Serpentine Systems-img_20150302_195406.jpg   R4 to Sanden for Serpentine Systems-img_20150302_195449.jpg   R4 to Sanden for Serpentine Systems-img_20150302_195534.jpg
Old Mar 3, 2015 | 10:26 PM
  #53
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
That's really good looking Deadbird. Great job!
Old Mar 4, 2015 | 06:18 PM
  #54
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Very nicely done.
Old Mar 4, 2015 | 08:33 PM
  #55
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
i cant tell by the pictures. is there enough room to fit tall valve covers?
looks great by the way..
Old Mar 6, 2015 | 06:40 PM
  #56
deadbird's Avatar
Engine: TPI 305/ v6
Thanks guys!
Lone, I don't know how much higher tall valve covers are over stock. Mine are not stock but, I'm reasonably sure they are not tall (as compared to the old M/T covers on my 71). I wanted the compressor fairly tight in clearance to what I have...
Attached Thumbnails R4 to Sanden for Serpentine Systems-img_20150302_195534.jpg   R4 to Sanden for Serpentine Systems-img_20150302_195608.jpg
Old Mar 19, 2015 | 02:22 PM
  #57
djdsails's Avatar
Car: 92 camaro RS
Engine: Moded 350 engine
Transmission: 5 speed
Question, How do i wire up this compressor?
Old Mar 22, 2015 | 09:51 AM
  #58
djdsails's Avatar
Car: 92 camaro RS
Old Mar 22, 2015 | 10:09 AM
  #59
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Stock GM connector has a Green wire from Accumulator Low Pressure switch. Connect to wire coming out of compressor (IIRC, there is only one wire on the compressor). Other stock wire is ground, and you should not need it, but can ground it to the compressor body if there is a ground connection.
Old Mar 22, 2015 | 10:11 AM
  #60
djdsails's Avatar
Car: 92 camaro RS
Thanks!
Old Mar 26, 2015 | 11:32 AM
  #61
Ozz1967's Avatar
Car: 1984 Trans Am
So since my wires from my car harness is a green wire with a resister built into it, is there anything I would need to modify on mine to get it to work?
I also have the single wire which I think is the pressure line wire. I'll get a picture up here in a bit to show you what I mean.
Old Mar 26, 2015 | 11:44 AM
  #62
darbysan's Avatar
It's not a resistor, but a diode. Not needed on the Sanden ( it's built in I think). You may have a High Pressure switch on the back of the R4. The power runs from the Accumulator low pressure switch, thought the green wire to the R4, then out the black wire either to ground or to the High Pressure switch ( which interrupts the ground when 450PSI is exceeded). On the Sanden, you go Green to sanden. Can't remember if the Sanden has a seperate ground wire, or if it just grounds through the bolts.
You may have a third set of wires to the High Pressure switch in the High Side Pressure Line. Just leave these alone- they trigger the fan ( at least that's what I use it for).
Old Mar 27, 2015 | 05:04 PM
  #63
deadbird's Avatar
Engine: TPI 305/ v6
darby is correct. the sanden is grounded to itself. you can see the blk/wht ground wire in post #52. it has a ring terminal and is screwed to the black part of the compressor.
Old Mar 29, 2015 | 06:37 PM
  #64
basiccamaro's Avatar
Some of those brackets that can be used to convert the stock Harrison compressors on the right (passenger) side, over to the Sanden compressors are from Old Air, in South Fort Worth, Tx. I'm not aware of any from Vintage Air.
I haven't started mocking up my project yet, but I plan on also trying to have 1" or so spcaers made to move everything out away from the block farther for more valve cover clearance.
Old Apr 6, 2015 | 01:23 PM
  #65
djdsails's Avatar
Car: 92 camaro RS
How much oil do I need to add to the system? The truckers Ac site gave a capacity, but do I need to add any extra?
Thanks!
Old Apr 6, 2015 | 02:58 PM
  #66
darbysan's Avatar
Thanks!
3oz in the compressor, 3 oz in the accumulator.
Old Apr 6, 2015 | 03:05 PM
  #67
djdsails's Avatar
Car: 92 camaro RS
Thanks!
So the compressor does not come with oil? And I have to add in 6oz
Old Apr 6, 2015 | 03:11 PM
  #68
darbysan's Avatar
drain any oil in the compressor. Some ship with oil, some do not.
Old Dec 1, 2015 | 12:48 PM
  #69
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Great info here. how much longer is the Sander over the R4?
Old Dec 2, 2015 | 10:37 AM
  #70
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
The Sanden is a couple of inches longer. You can Google Sanden compressors and they have a site somewhere that gives the dimensions.My R4 is mounted on the driver's side and I don't think the Sanden will fit without hitting the stock valve covers.
Old Dec 2, 2015 | 05:06 PM
  #71
mcquigg's Avatar
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
I have stock valve covers, no clearing problems what so ever with the Sanden compressor. The Sanden sits higher in the bracket than the R4.
Old Dec 3, 2015 | 01:20 AM
  #72
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
If you can, please post a pic. I would really like to replace the R4. Did the Sanden mount onto the R4 bracket?
Old Dec 7, 2015 | 01:07 AM
  #73
mcquigg's Avatar
Car: 85 T/A
Some of the early posts mention the Vintage Air brackets that adapt the compressor to the compressor bracket. I don't have access to the car right now but if I remember correctly there is around 1 or 2 inches of clearance between the compressor and the stock valve cover. Here is one photo I took before putting the car in storage unfortunately I can't find the other pictures I took during the install. Thanks to the pioneering work of darbysan this whole conversion was very simple.
Old Sep 1, 2016 | 05:49 PM
  #74
iron38's Avatar
just done this coversion on my 89 S-10 worked great. vintage air brackets worked just fine on the FLX7 compressor. stock hoses worked fine also. put in a Parallel flow condensor new dryer orifice tube. vacumed the system charged. works better than it ever has.cooling to 40 F on a 90 degree day.
Old Apr 26, 2017 | 08:24 AM
  #75
bwmcam's Avatar
Car: 1987 IROC Camaro T-Tops Rule!
Transmission: 700r4 Pro Built / 2600 vigilante tc
Great information guys! I am currently getting the parts list together for this. Which orifice tube did you use?
Old Apr 26, 2017 | 09:47 AM
  #76
mcquigg's Avatar
Car: 85 T/A
I used a variable orifice tube in my system.
Old Apr 26, 2017 | 09:52 AM
  #77
bwmcam's Avatar
Do you have a part number or know the vehicle it came off of so I could find it? Thanks!
Old Apr 26, 2017 | 09:59 AM
  #78
mcquigg's Avatar
Car: 85 T/A
I searched for an 88 Firebird orifice tube on Autozone's website. I think they're around $20.
Old Apr 26, 2017 | 10:00 AM
  #79
bwmcam's Avatar
Thanks Mcquigg!!
Old Aug 7, 2017 | 11:46 AM
  #80
ULTM8Z's Avatar
This thread was extremely informative...
I just did this swap. Holy crap... vents are blowing 36°F air now!
I'm running a Classic Auto Air system on my 1971 Camaro, but was running a serpentine system... so I was running a R4 before and was getting 42-43°F (which I thought was cold at the time). Decided to try the Sanden... glad I did.
I literally can't point the vents directly at me as it literally gets too cold now...
Any rate, thanks for posting this info!
Old Apr 3, 2018 | 10:30 AM
  #81
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
Can anyone tell me whether or not if my 1990 Formula already has a usable condenser? It only has 16,500 miles on it and I'm going to be converting to Sanden/R134a. Current R4 isn't bad, but it's short-cycling due to being low on R12. Not sure if I could get by with the condenser currently installed or if I should just buy a new one. Money is not the problem, but it would be nice to not have to pull the old condenser if I don't need to. True parallel flow condensers are $280 at Original Air...
Old Apr 3, 2018 | 10:37 AM
  #82
darbysan's Avatar
I doubt that yours has the parallel flow, as those came later. You can check by looking at your current condenser. If the ends of each row have a 180 loop into the next row, then it is not parallel flow. It will still work- it's just not as efficient.
If yours is installed in a similar fashion as mine, then it can be replaced by simply unbolting the radiator and tipping it back toward the engine. No need to remove the radiator hoses or fluid, but you might have to remove the fan. The condenser will be held in with two brackets ( 1 bolt each). Unbolt and lift up. I place a piece of cardboard between the radiator and condenser just to keep from messing up the fins.
Old Apr 3, 2018 | 09:26 PM
  #83
rt66er's Avatar
Engine: L31 350 TPI
Thanks. I see that Original Air sells a complete conversion for 88-92 F-body cars. A bit pricey (~$850 shipped), but it includes everything except the refrigerant and the oil. Takes out some of the guess work about what works well together. Of course, piecing it together is gonna be cheaper and probably work fine, as many on here have demonstrated.
Old May 13, 2018 | 03:00 PM
  #84
scatpack's Avatar
I'm doing this on a 83 cfi car. Has anyone done that yet?
Old Jun 11, 2018 | 12:11 PM
  #85
rt66er's Avatar
Engine: L31 350 TPI
I purchased and have installed the Original Air Stage 3 conversion (includes everything from evaporator to condenser). I can't get it to take more than 5 or 6 oz of refrigerant. After 30" vacuum for an hour, I let it suck in all it would take (vapor only), then started and turned on the A/C on max. The compressor short-cycles (~1 second bursts) but will not suck in any more refrigerant. Low side runs about 70 psi (at 85 degree ambient) and drops briefly to 30 psi when compressor cycles. High side won't get any higher than 110 psi. What am I doing wrong?
Old Jun 11, 2018 | 03:26 PM
  #86
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
on some application the high side line need to have an extension. #8 inline discharge port adapter worked for my suburban.
Old Jun 11, 2018 | 03:27 PM
  #87
Car: numerous
Engine: ls1, others
Check high side pressure. Might have to short the low pressure switch to get the compressor to pull down long enough to continue charging
Old Jun 12, 2018 | 08:37 AM
  #88
Car: numerous
Engine: ls1, others
This is is most up to date drawing I have for the brackets. The middle hole can be not drilled until test fitted to allow for small variations.
Attached Thumbnails R4 to Sanden for Serpentine Systems-tmp_17285-img_20180610_1118591424138657.jpg
File Type: pdf
Old Jun 12, 2018 | 09:46 AM
  #89
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I've got to get A/C back in my car.. Just wish this compressor wasn't so ugly..
Old Jun 26, 2018 | 05:43 PM
  #90
Val's Avatar
Val
A thank you to the guys who did the leg work on this.
I used the Dirty Dingo adapter kit and it worked fine. One of the spacers was a bit short, but it works without any issue.
https://www.dirtydingo.com/shop/prod...oducts_id=1622
I got everything from Napa other than the compressor itself which I sourced online. I reused my existing low pressure switch, and high pressure switch (on the hard line below accumulator). And since my car is a 91 it already had the ~sort of~ parallel condenser. Make sure you guys remember to jumper/splice the high pressure cut out switch/connector that was on the back of the R4. I forgot and had a hour of WTF!!?? why wont cycle!!!
The only real issue I ran into was the angle of one of hoses. It was kinking pretty hard, and while I know it would have pressurized without a problem I bent the tubing a bit to relive the kink a bit. Its working great!!! and today it hit 35F from the center vent!!! After owning thirdgens for 20+ years this life changing. Even R12 never worked this well.
Random pics:
hitting AIR system, and not even all the way back.
Suction side needs to be bent so it more of a 90 degree bend.
Kinked
Bending
Finished
Old Jul 29, 2018 | 01:12 PM
  #91
Val's Avatar
Val
Word of warning. That variable orifice tube took a **** on me. Howling and vibrating. (And AC no longer worked). Replaced it with a .062 orifice tube. I just got it from napa by asking for a 2006 F250 orifice. Blowing cold now.
Botken varible orifice
Granted this is at 10am and it was only about 87F.
Old Jul 29, 2018 | 06:22 PM
  #92
DynoDave43's Avatar
Originally Posted by Ozz1967
You know, what's funny is I think I'd be ok with it at first, but then it would bug the crap out of me if it wasn't sitting level. I'm again back to the, you want to make another set? hehe
Did deadbird ever decide to make these, or provide a dimension drawing? I much prefer the look of what he has done with that bracket.
Old Aug 10, 2018 | 12:32 PM
  #93
Popper's Avatar
Another question for Deadbird.... it is not clear to me if he made or had the 6 rib pulley made or if he purchased the 6 rib from the source he linked in the thread. The pix look like his pulley is machined whereas the link is a black poly piece.
Old Aug 13, 2018 | 08:53 PM
  #94
deadbird's Avatar
Engine: TPI 305/ v6
DynoDave, no, neither. Since the 'finishing' of the brackets, I lost a small wrestling match with some metal and had to have some procedures done to regain use of my left hand functions.
Turned out to be rather expensive and set me back quite a bit, in more than one way. S--t happens tho..
Popper, the pulley I provided the link to is still correct. The image is most likely a generic (or old) photo of the pulley with a crap gloss black paint job on it. Mine came with the pulley
non painted and the cluch painted oxide (satin) black. The 8 rib pulley that came with the compressor was the same way.
Attached Thumbnails R4 to Sanden for Serpentine Systems-orig_8rib_in_6rib_pully_box.jpg
Old Aug 21, 2018 | 12:03 PM
  #95
Popper's Avatar
Thanks for the update Deadbird!
Old Jan 8, 2019 | 10:52 AM
  #96
BigBlock73's Avatar
Car: 90 IROC original owner
Engine: 5.7
I'm getting ready to order the Original Air stage one kit and want the 6 rib pulley.
I spoke to them and they said they don't have the 6 rib as they use the universal 8 rib.
I looked on the Sanden site and didn't see one listed with the 6 rib.
Has anyone seen one that comes with the 6 rib? I know you can buy the clutch but hoping to save on the expense of purchasing another clutch.
Old Jan 8, 2019 | 11:06 AM
  #97
darbysan's Avatar
I used the 8 rib pulley with the 6 rib belt. No issues so far, and it's been several years. Just had to line up the pulley with the others, which was not much of a problem.
Old Jan 8, 2019 | 11:16 AM
  #98
BigBlock73's Avatar
Engine: 5.7
I know it will work but my OCD has me wanting to make it look as “factory” as it can.
Old Jan 8, 2019 | 12:18 PM
  #99
Ozz1967's Avatar
Car: 1984 Trans Am
I believe you can order them with the 6 rib pulley, you just have to call and ask.
Old Jan 8, 2019 | 12:26 PM
  #100
BigBlock73's Avatar
Engine: 5.7
Ozz
Call who?
