SBC TPI Water Pump plug
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
During the course of replacing my water pump, I was unable to remove the upper plug to transfer it to my new pump. So I stopped in @ Home Depot, and they had the perfect plug! 1/2" Cast Iron plug. Fits like a glove.
I applied some pipe cement to help seal. Just an FYI thread as I couldn't find the answer to this quandry. A 17mm 12 point socket/reversible ratchet gripped it perfectly.
Re: SBC TPI Water Pump plug
Yup, that would be the size... pretty standard stuff...
Except next time, use brass; that way, it'll pop right back out of there effortlessly, whereas the cast iron will be impossible to remove, again.
Engine: LB9 | LS1
eightsixseven
Dec 16, 2024 01:50 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Sanjay
Aug 12, 2015 03:41 PM
Street Lethal
Aug 12, 2015 11:33 AM
