Right side Heater Hose at core
Old Dec 16, 2012 | 10:16 AM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
I recently replaced my heater core...what a job. They built the car around the heater core. Anyway, I was able to carefully remove both hoses without cutting them and the heater core was factory. I noticed that the short hose that runs down behind the back of the engine head is clamped onto a steel pipe which makes its way back to the radiator. I don't need to replace that hose yet, but it got me thinking...how do you get to that hose clamp way down behind the engine? I sort of tried to "get at it" just for kicks and didn't see an easy way to do so. I was just curious if there was a trick or if I had to pull the head off? Just wanted to get a jump on this for future reference if that hose ever goes because it looks factory. '89 Firebird 305 TBI
Old Dec 16, 2012 | 10:42 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Right side Heater Hose at core
It's a really tricky one. I used a combination of different swivels and extensions on a 1/4" nut driver handle to get at it.
Old Dec 16, 2012 | 05:24 PM
Car: 2 T-Tops
Engine: 327/305
Cool, thanks. Just wanted to know that it can be done without pulling the head. Hopefully, I won't have to mess with it for awhile.
Old Dec 16, 2012 | 09:18 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
That pipe is held on with a screw,if you remove that it's a lot easier to connect that heater hose.
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
