Just another Dual Fan Problem
Old Jan 11, 2013 | 09:56 PM
wilkink's Avatar
Car: 1988 Pontiac GTA
Engine: L98 5.7L
I've read through every fan problem on this site and have yet to find the answer I need, mostly because I have no idea what I'm doing when it comes to electric entities. Got a dual fan setup on an 88 GTA with the 5.7. First thing I thought of was the fan switch, which I replaced a few years back with one from Hypertech. But if that went bad, it wouldn't cause both fans to be completely off at all times, would it? By the way, it is plugged in. Then I did the ALDL thing and only the drivers side fan comes on. Not sure if both should come on or what, but I guess it's a good thing that even one turns on. I have read that there are two relays, but I have no idea how to use a voltmeter to check if they are good or not. If someone could patiently walk me through this, it would be much appreciated as it is my daily driver, and need it ready for work on Monday. Thanks in advance.
I have a voltmeter, if I need it to check the relays.
Old Jan 13, 2013 | 01:43 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Re: Just another Dual Fan Problem
So the car is overheating? To test the passenger side fan start engine and turn a/c on high after couple minutes it should kick on.
Old Jan 21, 2013 | 11:10 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
It is easier to switch relays out to see. Just don't mess with your fuel pump relay.
customblackbird
Aug 15, 2021 10:16 PM
onefreakz
May 14, 2018 12:15 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
