Thermostat housing sensors
Old Jan 21, 2013 | 11:51 PM
Austin19's Avatar
Car: 1985 Camaro Z28
Engine: 305 LG4
Axle/Gears: 3.08
I searched around and found a ton of threads on this but none match what I'm looking for. I have a non-CC LG4, no smog equipment, with the stock air cleaner removed, so no need for EFE (IIRC thats what the thing from the pass. manifold to air cleaner is called). I'd love to get a round thermostat housing so I don't have to mess around with any of the stupid gaskets, and just get a simple O-ring. Both sensors have NO wires, only one vacuum line to the carb and one to some other location (haven't had a chance to track them down). What do they do? Do I need them?
PS - no electric fans either.
Old Jan 25, 2013 | 11:02 AM
91CamaroRS101's Avatar
Car: 91 Camaro RS
Engine: 3.1 V6
Transmission: 700R4/4L60E
Re: Thermostat housing sensors
If it is like Ford it should be a vacuum line to the distributer to prevent the vehicle from overheating at idle and switches from ported vacuum from carb to direct vacuum to the intake manifold. Then it advances the timing. To delete it from the distributer plug it into the intake manifold itself.
Old Jan 25, 2013 | 11:34 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
TVSV - Thermostatic Vacuum Switching Valve
https://www.thirdgen.org/forums/tech...iagrams-i.html
Old Jan 25, 2013 | 05:38 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
One 'sensor' is what tuned posted above. The other would have been your coolant temperature sensor for the ECM. Neither needed if you're running a standard carburetor/distributor.
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
dbrochard
Oct 3, 2015 12:43 PM
85Special
Sep 3, 2015 04:21 PM
Formula_88AE
Sep 3, 2015 01:47 PM
