A/C Vacuum problem/ flap door problem.
Old Feb 3, 2013 | 10:12 PM
Dvolion11's Avatar
Car: 88 Camaro IROC, 92 Camaro RS.
Engine: 305 tbi, LT1
Transmission: 700r4, 4l60e
Axle/Gears: 3.43
When taking the heater core cover off I noticed the flap door next to it was broken(The plastic that holds the door is broken). It doesn't function with the controls at all. Anybody know what this door is for? I have the picture below. Also does anybody have a A/c Control Vacuum diagram? My a/c blows but not as it should. when defroster is selected it still blows through every vent.
Attached Thumbnails A/C Vacuum problem/ flap door problem.-photo_zps6405477e.jpg
Old Feb 5, 2013 | 06:08 PM
Dvolion11's Avatar
Axle/Gears: 3.43
Re: A/C Vacuum problem/ flap door problem.
Anybody?
Old Feb 5, 2013 | 06:35 PM
JesseShredd's Avatar
Car: 1992 Camaro RS
Engine: 1978 L82 355
If I remember correctly, when closed it blocks off the heat when AC is engaged.
Old Feb 5, 2013 | 06:37 PM
Car: 1992 Camaro RS
It's ran by a mechanical cable, not vacuum. All the other controls and doors are controlled by vacuum.
Old Feb 6, 2013 | 12:21 AM
Dvolion11's Avatar
Axle/Gears: 3.43
Would it be the same cable the Cold/Hot switch is ran by? Also how would you repair this? The door doesnt function at all. When I move the switch from cold to hot I see a cable move right under the heater core but it doesnt move the door at ALL. Im new to all of this. Any help is highly appreciated!
Old Feb 6, 2013 | 06:32 AM
Right: "hot/cold" is not a "switch"; it controls how much of the air passes through the heater core, by moving that door. "Hot" = all the air passes through the heater, "cold" = all the air goes around it, "anywhere in between" = ... no doubt you get the picture.
The cable end (which you can see in the pic) attaches to a little arm on that door, on the "back" side as shown in that pic.
A "diagram" for the HVAC control would be a waste of bandwidth. All it would be, is a little valve with one input and 3 or 4 outputs, that routes vacuum to any of 3 doors and maybe a valve. The 1st controls whether it's in "heat" mode or "dash vent" mode; then if it's in "heat", another controls whether it goes to the floor or to the defroster; then the 3rd one (labelled "max" in most of these cars) controls whether the blower intake "recirculates" (draws air from under the dash) or draws in fresh air from outside. "Normal" (no vacuum applied to anything, is heat, defrost, and outside air, respectively. Some of these cars, not sure exactly which all, have a 4th vacuum output, that goes to the heater control valve; that valve controls whether hot water is allowed to flow in the heater core. If memory serves, "normal" (no vacuum) for that one, leaves the valve open; and vacuum applied to it, closes the valve and shuts off the hot water flow.
Old Feb 7, 2013 | 12:44 AM
Dvolion11's Avatar
Axle/Gears: 3.43
Do you have any tips to fix the door? I see one door that moves when switching hot/cold its close by the door that im taking about. The plastic is broken, and does not funtion at all.
1992 Trans Am
May 10, 2023 07:19 PM
db057
Sep 4, 2015 07:57 AM
hepcat620
Sep 2, 2015 11:51 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
