What temp fan switch to get?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
84 T/A, single electric fan. L69 motor.
What temp fan switch should I get to go with a 180* thermostat?
If I run a 180 T-stat to go with a 205 on, 195 off Fan switch, will the fan have less of a duty cycle or more? Would I be better off going with a 195 on 185 off switch?
The reason I'm asking is because the connector on my fan switch melted off and I need to get a new one (as well as try and find a way to keep the lead from melting off in the future). I just want to get one that will fit best with my current application (Aluminum Radiator, 180* T-stat).
Any and all advice is welcome! Thanks!
Car: 1984 Trans Am
Re: Fan Switch Question
Because the actual temp would barely ever get below the sensor "off" position, even when running on the highway?
Or do I need an "off" that's below the 180* of the T-stat?
Seems to me that it would be better having one that's slightly "higher" in temp would be better right?
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Mostly because thermostats aren't 100% precise. You'd want a shut off temp at least 10-15° above your t-stat temp, if you want you fan to cycle on/off.
Car: 1984 Trans Am
Engine: TPI 305/ v6
A factory fan switch will turn on at 238°F. I used a sw505 (a-zone, 215°) fan switch on my 91 which is reasonably close to the ECM fan control temperature(220°) and was practical on a stock 305 TBI with a 195° t-stat .
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
