New guidance on oil cooler hose type
Old Feb 23, 2013 | 10:48 PM
joef2002's Avatar
EDIT TO TITLE: "NEED" Guidance
Hi everyone - 88 GTA 350 TPI. I'm doing my damdest to try and minimize the leaks underneath. The oil cooler is my next to do. In the pic you'll see what my lines currently look like running to the cooler. it's a metal line that has about 4" of rubber hose connecting it to the oil cooler. I would like to replace these 4" rubber hoses with new ones and had two questions:
1) What type of hose should I get? And what diameter / size? (I'm 99% positive the lines just hold coolant.)
2) Do I have to drain the entire coolant system before replacing them? Or can I keep it full and just expect a minimal amount to come out when I disconnect them?
Thanks!
Old Feb 24, 2013 | 12:35 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: New guidance on oil cooler hose type
It is regular 5/8" heater hose. It's the lowest point in the system, so it will make a mess when you remove the hoses. You can minimalize the coolant loss if you clamp off the 2 rubber hoses at the other end of those pipes.
Old Feb 24, 2013 | 10:51 AM
joef2002's Avatar
Ok thanks. I've spent more time in the past two days under the car than I ever want to again. A little coolant will just add to the fun and filth!
Hotrodboba400
Dec 10, 2019 07:07 PM
tommy z-28
Oct 6, 2015 10:58 PM
ericjon262
Sep 11, 2015 06:07 PM
apie2546
Sep 5, 2015 07:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
