incorrect gauge readings
Maybe the gauge in the car is accurate.The sender for the gauge is between #1 and 3 combustion chambers.The cts is in the intake manifold.It makes sense that the temp between the chambers is going to be hotter than it is up in the intake manifold.How many degrees I don`t know but maybe when the gauge says 220 the cts is seeing only 205.
Re: incorrect gauge readings
Have you checked the wire coming off the unit for corrosion? Does the gauge move when you turn the key? If so you might have it shorting out at some point. My 91 350 had a improper ground, changed the wire, electrical taped it and replaced both sensors just to be sure.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Ghettobird52
Jul 5, 2024 11:18 PM
