How do I remove the lower evaporater case?
Old Mar 30, 2013 | 09:45 PM
mustangdmurder's Avatar
Car: 1982 Z28
Engine: three 350s, all casting #370010
I can't figure out how to get the dang thing off. If anyone could help it'd be appreciated pictures would be great. It is in a 1982 z28 camaro.
Old Mar 31, 2013 | 09:44 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: How do I remove the lower evaporater case?
just unbolt it. If I remember right, there is one or 2 you have to get from inside the car.
Old Apr 1, 2013 | 07:53 AM
Car: 1982 Z28
That would explain it.
Old Apr 4, 2013 | 06:30 AM
Yup, a coupla bolts under the top edge of the carpet.
You'll find that it's easier to take the whole thing out and THEN take it apart, than to take the halves out separately.
Go visit a car assy plant sometime and watch em put cars together. Notice that as they put em together, they spend 37 seconds or whatever, at each workstation... 37 seconds to put in a seat, 37 seconds to put on a door, 37 seconds to put in the A/C evap hsg, 37 seconds 37 seconds 37 seconds .... If it only takes 37 seconds to put in, can't take very long to take back out again either, eh?? (might not be exactly 37 seconds for every prod line; might be 28, might be 53, might even vary somewhat from day to day depending on how may they're producing; but I'm sure you'd settle for 53 seconds instead of 37)
Then learn to take em apart the same way. I can assure you, they DON'T put those things into cars one little piece at a time.
Old Apr 4, 2013 | 09:01 AM
Car: 1982 Z28
I got it out yesterday it was the 2 bolts inside that were holding it in. Thanks for the help guys and Sofakingdom it is easy once you find it and if it isn't rusty.
Old Apr 5, 2013 | 05:26 PM
Go visit the Vette plant in Bowling Green KY. A short jaunt from anywhere in OH. You'll be amazed at how little you know about how cars are put together; and how valuable just knowing how it's done, can be, when attempting to restore one.
You'll drive right by a Honda plant in Columbus and a Toyota plant in Georgetown KY as well. Might as well make a day of it and tour em all.
customblackbird
Aug 15, 2021 10:16 PM
NBrehm
Aug 25, 2015 11:49 PM
86camaroman201
Aug 19, 2015 04:52 PM
Street Lethal
Aug 14, 2015 08:25 PM
3rdgenparts
Aug 8, 2015 07:09 PM
