A/C help?
Car: 1984 Trans Am
Engine: 305 cui
A/C help?
so i went down to my friendly repair shop in town that carried R-12 Freon and i believe Freeze-12. i don't really know what was put in there, but was given the option for 2 bottles costing 50 bucks each or 2 bottles at 25 each and, you guessed it, i went with the cheaper. For some reason the A/C seems to be not as cold as it can be. i don't know how much Freon has to be put in but i think it might not be enough. A friend of mine with a 87 camaro said i need to put 4 cans in while the internet is talking about 2 1/4 for R-12. i don't know whats in my system (probably Freeze-12 since i went with the cheaper Freon.) but ,my a/c feels weak and the compressor isint staying on, as i belive it should should so it get me thinking. My car is a 1984 Trans Am with the v8 engine if that info helps
Thanks for the help!
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: A/C help?
First off, R12 shouldn't be mixed with Freeze 12. Freeze 12 is a combination of other refrigerants as it's make up, Was this system working fine last summer but not now since over the winter ? Did this so called "shop" leak test your system ?
My chart only goes back to 1986 and that shows 48.00 oz for a empty system, When adding refrigerant to a system one doesn't go by a certain number of onces but by reading the low and high side gauges. It's anyone's guess as to how much is still in a system or how much is required to reach the proper level per the gauges, Since your compressor isn't staying on or cycling often is a sign of a low refrigerant level.
If I don't know what refrigerant is in a system by looking at the service ports for conversion adapters or find no conversion decals, I empty the system and start from scratch.
What I mean from scratch is, When done properly you can get satisfactory results using good ole R134 refrigerant.
Remove the compressor and drain all existing oil and re-fill with ester oil (using the 1986 example above would be 8 oz's), Flush all lines-evaporator and condenser with a AC flush solvent. Replace the orifice tube and receiver dryer then pull the system down and re-charge to the appropriate/recommended gauge readings, Then you should be good to go.....
Car: 1984 Trans Am
Engine: 305 cui
Re: A/C help?
I think it has freeze 12 since freeze 12 is cheaper then R-12. But this morning I went to turm my a/c on, I a didn't even hear the compressor activate. I told the mechanic to CHECK tge system before putting the freon and he assured me it was not leaking and holding charge
Car: 88 GTA
Re: A/C help?
If this were true a red flag should have went up with your "mechanic", A sealed non leaking system shouldn't have taken two cans of refrigerant.
And now the compressor won't even kick in ?!?!
Me thinks you need to find another "mechanic"......
2012sergen11
Oct 13, 2015 07:38 PM
