a/c issues with '86 firebird
Car: 1986 Firebird
Engine: 3.4L Swap is done
Axle/Gears: Stock
ok all here is the issue,
pulled the engine and everything out of the engine compartment, put everything back in, ran the car for about 6 months now that its starting to heat back up decided to recharge the a/c. the a/c was converted over to 134a and ran fine before pulling it out. but now I got good pressure on the low side, 1 and 1/3 bottle in and the compressor will not cycle, the receiver pressure sensor is closed the high pressure sensor is closed. haven't checked the compressor clutch relay yet (haven't found it), I have power going to the two sensors. now connecting a wire to the green wire on the clutch will engage it and the pressure will come down but I don't want to finish filling it that way either. any ideas and the location on the clutch relay would be helpful
Car: 02 T/A WS6, 91 Camaro RS
Engine: LS1, 305 TBI
Re: a/c issues with '86 firebird
I'm having problems trying to find the clutch relay myself. Did you find it and if so where is it located? I have a 91 RS 305. My compressor will not kick in. Wanted to see if it will work before i charge it up. Its completely empty. I tried jumping the the low side pressure switch on the accumulator with a paper clip. Also I used a voltmeter to test the clutch connector,,,nothing. I had to directly jump the prongs on the compressor clutch to the battery, the clutch clicked but thats it. Any thoughts?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
The compressor clutch will not kick on if your system is empty.
Car: 1986 Firebird
Axle/Gears: Stock
The relay is on the driver side on my '86 it might not be there on you '91, but there are two switches a hp and lp. The lp is on the low pressure side( closed with your system full) and the hp is on your high pressure side ( it makes sure the system is running right I believe it's normally closed) but both of these switches have to be closed for your system to engage the clutch
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
BikeFarm
Aug 11, 2015 11:35 PM
db057
Aug 11, 2015 10:11 PM
