IROC barely getting above 100 degrees
Old Apr 15, 2013 | 11:07 PM
ZChaseman's Avatar
Car: 1986 IROC-Z Camaro
Hey guys last year i put a new factory thermostat in the Camaro thinking that it would fix the temperature gauage not moving. Now, it reads barely over 100 degrees when driving it, BUT when left to idle it will reach 210-220 range and fan will come on and cool it back down. I dont know what else to try, Any suggestions?
THANKS
Old Apr 16, 2013 | 06:50 AM
Re: IROC barely getting above 100 degrees
When you changed out the gauge sending unit, how much difference did it make?
When you shot the head castings and the water outlet with your infrared thermometer, what was the actual casting and coolant temps?
Old Apr 16, 2013 | 08:10 AM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
If you got anything but ac delco it probably doesn't work. I've tried 4 aftermarket coolant temperature senders all read way off.
Posted from Thirdgen.org App for Android
Old Apr 23, 2013 | 10:35 PM
gm muscle's Avatar
Car: '89 Iroc-Z
Engine: 5.7 TPI
Transmission: 700 R4
Axle/Gears: 2.77
I don't think he ever stated he replaced the temp sender, just the thermostat. I have the same issue as well.
Old Apr 23, 2013 | 10:37 PM
ZChaseman's Avatar
I did change out the sending unit also. Think the gauge may just be malfunctioning?
92camaroJoe
Jul 29, 2023 07:57 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Irocohio
Aug 12, 2015 08:03 AM
mustangman65_79
Aug 11, 2015 03:17 PM
