rust in radiator
Old May 4, 2013 | 07:09 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
rust in radiator
empty coolant overflow tank, and rust in radiator and on cap. just recently noticed 2 weeks ago, overflow tank needs to be replaced but never got around to it. wonder if that caused it.
how much of a problem is this and should i be worried?
Old May 4, 2013 | 09:45 PM
joshc's Avatar
Car: 1986 Trans Am
Re: rust in radiator
Replace your overflow tank and flush out your cooling system. Conventional green coolant only has a service life of 2 years, then the anti rust and corrosion additives lose their strength.
Old May 6, 2013 | 06:21 AM
Berlyn0963's Avatar
Car: 91 Camaro RS
flushed system and replaced overflow.. ill keep an eye on it still.
Old May 6, 2013 | 04:58 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
Could also be casting sand from the block. I had this issue with my TTA, I thought it was rust until I removed the radiator and tore the side piece off. The bottom 3-4 inches of the radiator was filled with brown sand.... IMO you need to replace the radiator.
sheachopper
Jul 31, 2019 11:27 AM
Fireslash
Apr 11, 2016 06:43 PM
