What cooling fan, fans have you used?
Old May 20, 2013 | 09:27 AM
Beeman's Avatar
I have a stock radiator and the original single fan on my 85 Camaro. Car is not street driven only bracket raced. Fan is only 28 years old so what could go wrong? Seriously the fan works but takes longer between rounds for me to cool it down than I'd like in hot weather. What fans adapt nicely to fit a 3rd gen?
Old May 28, 2013 | 12:06 AM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Re: What cooling fan, fans have you used?
I have several LT1 4th gen fan setups....they fit nicely as if they're made for the 3rd gen radiators too. I also make a variety of HD relay harnesses for them also. They have a better shroud design so pulling out more heat is much improved.
Old May 28, 2013 | 10:30 PM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
I installed the dual fans out of an 02 camaro. A little modding needed but a great fit.
Old May 29, 2013 | 07:30 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I left the stock fan and setting in the stock location as back up for a 16in. front pusher fan with a adjustable fan thermally controlled switch set at 190* with a 180* thermostat.
Old May 29, 2013 | 11:15 PM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Did your pusher fan fit in front of the condensor? I am currently looking to do something like that for my car.
Old May 31, 2013 | 08:34 PM
Engine: TBI,5.0
Yes but I had to remove the bolt from the bottom of the support "V" bracket and extend it out with a longer one. 16in was really pushing it when working it in there but it is a beautiful fan/shroud. I pulled it off of a car at pick n pull a few years ago .The reason I like the pusher stock fan combination is because I have a large 14in x 17in. oil cooler with the stock 12in. puller fan mounted to it. (Its a push pull fan sandwich) .I say stock but the fan comes on closer to 200* as opposed to the higher stock setting. During the hot months the car rarely sees 220* in stop and go traffic. So that's a 16in. front pusher fan on at 190* with a stock puller fan that is on at 200* with a 180* thermostat. I get mixed reviews here over it.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
