lower temp fan switch
Old May 20, 2013 | 10:11 PM
joshc's Avatar
Car: 1986 Trans Am
I have an 86 TA with the single fan. I am running a 180 thermostat. I would like to change the fan switch to one that turns the fan on at 200 and off around 185.
I know I could spend $40 on a hypertech, but I was hoping to find a part readily available at a local parts store.
I found a thread listing some Advance auto GP Sorensen numbers, but they are no longer good numbers from advance.
Thanks!
Old May 20, 2013 | 10:38 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: lower temp fan switch
Just use one of these.You can even wire in a toggle switch that allows you to turn the fan off when running or off before it starts running. The switch is temperature controlled and is adjustable so you can set it where you want.Its also very simple to wire in.
http://www.autozone.com/autozone/par...artNumber=true
Here's the diagram. It does use a probe.
Old May 20, 2013 | 10:47 PM
Engine: TBI,5.0
Also this switch can be found at Autozone under # 4028.
http://www.summitracing.com/parts/hyp-4028
eightsixseven
Dec 16, 2024 01:50 PM
89GTAOz
May 16, 2020 09:31 AM
krisner89
Oct 10, 2015 06:03 AM
TA8487
Aug 16, 2015 12:21 PM
