1988 iroc loosing coolant
Old Jun 17, 2013 | 10:29 AM
88zroc's Avatar
Car: 1988 iroc-z
Engine: 5.7 tpi
Transmission: 700 r4
My camaro is loosing coolant,new hoses,cap and pump have been installed.Has no external leaks or heater core leakage,no water in oil,engine runs great.I guess it may be going out the exhaust,any ideas or experience with this problem?
Old Jun 17, 2013 | 08:51 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
Way to post this in more than one thread.
Posted from Thirdgen.org App for Android
Old Jun 17, 2013 | 10:32 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Re: 1988 iroc loosing coolant
If there is no external leaking (you need to be sure) and your oil isn't coming out milkshake, coolant is leaking into the cylinders and out the exhaust during engine operation. (head gasket time) If it's a noticeable amount, you should be able to smell it in your exhaust.
Old Jun 18, 2013 | 04:41 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Also if you put your fingers under your exhaust, they'll come back wet...it'll be noticeable.
Old Jun 18, 2013 | 06:04 AM
88zroc's Avatar
Car: 1988 iroc-z
Engine: 5.7 tpi
Maybe,but it could also be the intake gasket leaking.The results would be the same,water in the cylinders,just wish I knew a way to tell which.
Old Jun 18, 2013 | 11:17 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Do a compression test of the cylinders.
Old Jun 18, 2013 | 11:58 AM
rwstegne's Avatar
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
I had the same problem with my 89 TPI. I just went to autozone and used their block tester which is straight forward chemistry experiment and it confirmed that I had a leaking headgasket. So hopefully I will have it on the road again before the 4th.
Old Jun 21, 2013 | 04:51 PM
Keoman's Avatar
The way I see it, IM or head gaskets, you still have remove the same parts.
Go to autozone and buy head gaskets and an IM gasket set
Tear the intake down.
Found the leak! Yey! Fix it and return the head gaskets.
If not, keep going...
No need confusing yourself with all the "testing" to figure out what you already know. In the end, you have an internal coolant leak.
Old Jun 21, 2013 | 08:42 PM
rwstegne's Avatar
Engine: 5.7L
Well, in my case both the intake and one of the head gaskets were leaking. The thought process was to verify the head gasket first prior to fixing the obvious intake leak, but I am not mechanic.
stalkier
Aug 21, 2015 01:54 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
kyleb24
Aug 15, 2015 08:24 AM
Randomtask2
Aug 13, 2015 01:57 AM
mustangman65_79
Aug 11, 2015 03:17 PM
