A/C Vacuum Manifold?
Old Jun 26, 2013 | 05:57 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
I'm trying to track down why I'm only getting air out of the vents and nowhere else no matter what setting I put it on. I saw some others commented in other threads about removing a A/C vacuum manifold and a resistor being bad. I'm just not 100% sure where this is but I know I'm in the right area. I've attached pictures of what I thought it may be. Any help would be greatly appreciated.
Old Jul 2, 2013 | 04:47 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Venting His Frustration
There is no “resistor” in the blend doors operation.
When you say “vents” you didn’t say which ones so we will assume defroster vents.
The problem is usually caused by weak or no vacuum going to the mode selector.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is Sliding On It’s Roof
gta892000
Aug 11, 2019 11:16 AM
86CamaroDan
Sep 29, 2015 10:08 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
camarohelp
Sep 12, 2015 05:45 PM
m00n420
Sep 11, 2015 02:39 PM
