I want ac in my 88 gta
Old Jul 10, 2013 | 08:53 AM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so im looking into putting ac back into my 88 gta back when i was in my teenage years i was never about ac. The po of the car put ac delete pulley an heater box in my 88 gta but now i wanna put ac in it. What would i need to get so i can install it back into my car. All the vents do work an blow out the defrosters an also blow out the interior vents so i know im getting vacuum to the vent controls vacuum canisters. An also i believe are cars ran r12 but i would need to convert it to r134 if im correct
Old Jul 11, 2013 | 06:19 PM
Engine: LR4 4.8
Re: I want ac in my 88 gta
Bump 70 views and no one can help out !!!!!
Old Jul 11, 2013 | 07:21 PM
Deancrew's Avatar
Car: 1991 z28 Camaro
Engine: 5.7 TPI
Axle/Gears: Posi with 323
I can't help with what you need to get all back into the car for the AC to work but when you do get it back in you could use stuff called hot shot it is a replacement for r12 and will work in that system no problem. I live in az and get my cans from a AC supply shop called job stone supply. The hot shot or r12 works alot better than r134. 134 sucks
Old Jul 11, 2013 | 07:22 PM
Deancrew's Avatar
Engine: 5.7 TPI
Sorry AC shop is called johnstone supply
Old Jul 20, 2013 | 10:11 PM
Engine: LR4 4.8
Ok so i got a complete ac unit from a private seller parting out a 92 3rd gen camaro got all the ac high side hoses, low pressure steel lines, compressor, evaporator, all switches, and the condensor with ac heater box. Now im wondering if there is r134 conversion kit i domt wanna run r12 since very hard to find and buy these days is there a company out there sells these kits for a decent price im gonna be installing this over the next couple of weeks so i would like to get all the info as possible before i get started on it
Old Jul 20, 2013 | 11:26 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
So do you have AC gauges and a vacuum pump, too?
Old Jul 21, 2013 | 10:08 AM
Engine: LR4 4.8
No seems like im gonna need to get that i could always install the whole ac system the. Use the ac machine at work to recharge the system
Old Jul 22, 2013 | 12:01 AM
baddone88ta's Avatar
Car: 1988 Trans am gta
Engine: 396 Stroker sbc
Transmission: 700r4 3000 stall
Axle/Gears: 9 bolt posi 2.77 gears
just make shure you clean the old r 12 oil out of the condenser , evaporator and compressor also get a new dryer. and new orings on every connection the r 12 oil when mixed with the 134 oil will eat the orings. I have put several retro fit kits on old r 12 systems and they work if you clean the system. Good luck!
Old Jul 27, 2013 | 12:14 AM
Engine: LR4 4.8
Sweet this is exactly what i needed to know can someone show me what the ac dryer is i never even heard of that in the ac also a pic of the evaporator as well
Old Jul 27, 2013 | 11:51 AM
Nunazet's Avatar
Car: 1985 Trans Am
Engine: Stock 305 converted to carb
The evaporator is the small radiator in the middle that goes in the heater box, the dryer is the silver can upper right. It mounts to the evaporator. It must be replaced any time the system is exposed to air. Keep the new one sealed till your ready to pull vacuum and put in the 134a.
Old Jul 27, 2013 | 12:34 PM
Nunazet's Avatar
Car: 1985 Trans Am
Hope these are helpful
Parts you may need...
O-ring kit http://www.ebay.com/itm/230831359348...84.m1497.l2649
O-ring lube and thread seal...
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
How to videos
How AC works:
Using gauges:
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
