a/c low pressure switch adjustment screw?help
Old Jul 24, 2013 | 09:16 PM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
can anyone give me any info on wether im supposed to turn the screw clockwise or counterclockwise to kick the compressor on at a lower temperature?
i heard its an easy mod but im not sure which way im supposed to turn the screw? (running r134)
anyone got any info?
Old Jul 25, 2013 | 11:14 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: a/c low pressure switch adjustment screw?help
Turn it about 1/8th counter clock wise.......So if the screw is pointing at 12 o clock, turn it to the left so that it's pointing about 10 o clock.
Old Jul 25, 2013 | 11:43 PM
Car: 1986 Iroc-Z
Engine: 355
thanks for the reply, what exactly is supposed to happen when the screw is turned counter clockwise?
Old Jul 26, 2013 | 01:30 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
It lowers the cutoff pressure for the compressor making the compressor run longer, giving colder air.
Old Jul 26, 2013 | 02:09 PM
Car: 1986 Iroc-Z
Engine: 355
thanks for clarifying i turned it counter clockwise hopefully runs cooler
Old Jul 29, 2013 | 11:18 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
If it has gradually gotten warmer, that is probably a bad idea.
Still running R12? leaky system?
Old Jul 30, 2013 | 01:52 PM
Car: 1986 Iroc-Z
Engine: 355
its pretty cold im running r134 so far it seemed like the screw made a minimal difference but a difference for sure, i might give it another 1/4 turn
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
jackhammer
Aug 15, 2015 10:04 PM
