A/C high side port 1992 Camero
Old Aug 29, 2013 | 10:29 PM
canticle's Avatar
My mom's '92 Camero A/C is not cooling. I went to attach my manifold--low side to the accumulator with standard R12 fitting, however, the high side is giving me fits. 3/16" fits the treads, but the valve appears to be 1/4 - 1/2 inch farther down inside the body. To try and clarify, the standard 3/16" adapter has the rigid bar (that depresses the schrader valve) that is about even with the rubber seal and above the threads of the fitting. The adapter I apparently need would have a rigid bar extending at least a 1/4" below the seal, perhaps even with the bottom of the threaded portion of the fitting. I did stick a thicker wire down into the port and a gentle push does cause the valve to vent, but I have never seen a manifold adapter that would function this valve. Does anyone know how to get the needed adapter.
Old Sep 8, 2013 | 01:42 PM
joeld's Avatar
Car: 1986 Firebird, 1989 Vette, 1995 GP
Re: A/C high side port 1992 Camero
I think this is what you need.
Joel
http://www.ackits.com/merchant.mvc?S...=chargeadapter
Old Sep 9, 2013 | 01:45 AM
canticle's Avatar
Thank you so much for the reply!!! Internet searches, talks with local mechs, etc...has turned up very little...but the picture in the link you posted has the look of meeting the need. Thanks again!
Vintageracer
Jan 10, 2020 05:33 PM
Cameeeero
Aug 20, 2015 03:06 AM
TA8487
Aug 16, 2015 12:21 PM
