A/c delete question
Car: 85 camaro
Engine: Carburated 305 V8, 2.4L 4banger
A/c delete question
I am planning on taking out my a/c on my 305 carbureted engine. I also want to take out the a/c condensor. It looks easy to take them out. But what do i do with the hose that go from the ac to the radiator? And what do i do with all the open connections when the condenssor is out? Do i plug them up? Are there caps or plugs i can buy? Thanks
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: A/c delete question
have the refrigerant evacuated and a vacuum put on the system. the receiver dryer will be a loss.
Car: 85 camaro
Engine: Lb9
Transmission: M20
Vacuum is the oppsite of pressure ! It is illegal to open the ac and let the refrigerant go to the atmosphere.
Car: 85 camaro
Ok thank you for that information. Are certain caps or plugs that i get for the open connections from the radiator and the condenssor?
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Why? If you are thinking that you may want to reinstall it at some point, save yourself the trouble and dont take it out!
If you just have to have it removed, then remove it cleanly.
If you are talking about caps while in storage, then a plastic bag with some duct tape to secure it would be fine to keep dirt out.
I dont recommend removing it though.
BlackphantomZ28
Aug 21, 2015 07:12 PM
BikeFarm
Aug 11, 2015 11:35 PM
