radiator porblems, top half hot bottem cold.
Old Nov 9, 2013 | 08:15 PM
Tom Swenson's Avatar
Car: 1991 camaro RS
Transmission: carb, 350
so i bottemed out today and all of my radiator fluid shot out of the cap and drained out. i took the car home, and flushed the radiator twice with a hose. when i turn on the car the top half of the radiator is hot, as the bottom half is ICE COLD. i think the radiator is clogged. any tips ?
Old Nov 11, 2013 | 05:00 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Radical Radiator
You didn’t say if the engine is now overheating.
If the radiator is original replace it.
It’s a fast swap.
But if you’re on a budget you can check the radiator by removing it, capping the bottom, fill it with water.
Now, uncap the bottom and see how much the flow-out is.
Then invert the radiator and see if the water flow-out from the top is more.
If yes, the radiator is clogged.
A well maintained radiator will look as beautiful 20 years later, as it did new.
Happy Racing!
You Know You’ve “Arrived” When Bikers Rev Their Engines When They’re Beside You
Old Dec 2, 2013 | 06:53 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Re: radiator porblems, top half hot bottem cold.
You either collapsed it or, the water pump cavitated when the fluid shot out and its shot now as well.
1992 Trans Am
May 10, 2023 07:19 PM
diana227vegas
Jul 8, 2016 12:27 AM
86Base
Aug 8, 2015 01:34 PM
