Cooling Question?
Old Dec 4, 2013 | 11:35 AM
Astrozombie81's Avatar
Car: 88 Iroc Z
Cooling Question?
Just curious about whats going on. My 88 runs normaly about 160 to 175 no problems. but when i am in traffic it rockets to 210 or more. I understand this is due to air flow but my question is why dosent it stabilize like other vehicles? Ive read the total cooling article and I have a manual control switch to one of my fans which i turn on in traffic and she stays steady. I just dont think i should have to use it as much as I do. thanks for the info.
Old Dec 4, 2013 | 04:34 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Re: Cooling Question?
I've always thought the 3rd gen fans are inferior to later model 2-speed ones but a lot of guys stick to the oldies.
Old Dec 7, 2013 | 03:47 AM
timberjake's Avatar
Everytime you need to switch the fan manually while in traffic ?
Old Dec 7, 2013 | 10:15 AM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
There is nothing wrong with your car.
It is designed to run hot for emissions/fuel burn in traffic. Fans without manual switches get even hotter. The fan automatically kicks on at 227* and kicks off at 210*. AF doesn't boil until it gets to 235* or more depending on pressure
When your car is moving cool air is forced thru the radiator, that's why it warms up in traffic -no air flow, hence the need for a fan to pull air thru.
So 210* is nothing.
Old Dec 7, 2013 | 12:32 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Besides, your temp gauge reads cylinder head temps so it will read a bit warmer than what the engine is actually running at through the intake-typically, its a 15-20 degree difference.
Old Dec 9, 2013 | 09:46 AM
Car: 88 Iroc Z
cool thanks for the good info.
Old Dec 16, 2013 | 02:21 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I have a 215* fan temp switch and in traffic my gauge spikes to the hash mark between 220* and 240* before it turns on...so I know my guage is off. Assuming the fan actually turns on at 215*.
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
