installing new coolant fan sensor question
Old Feb 24, 2014 | 08:17 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
just double checking….
do no use teflon tape on the threads of a fan coolant sensor because it needs to be grounded on the engine block.
I'm just concerned of leaks but should be ok right?
Old Feb 25, 2014 | 07:45 AM
Re: installing new coolant fan sensor question
Yes Teflon tape is fine; as long as the thing is screwed in enough to where some of the threads cut through and make contact.
You can measure for continuity between the shell of the sensor and the casting, to verify.
Old Feb 25, 2014 | 06:01 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
For any fan that is being run with the switch in the head there is an alternative to that switch. A thermostat controlled adjustable switch that cost $17.99 and should take less than an hour to install and it uses the stock wiring .You will be able to lower your operating temp. I use one of those switches and have it set at 190* with a 180* thermostat. That's where my car runs most of the time.
That is unless guys are happy about running those high temp.
I have mentioned this switch many times for guys that want to lower their operating temp or fix a fan that is on a manual switch.
Here’s the switch part
# 733653 and link = http://www.autozone.com/autozone/par...67187_69565_0_
Heres the diagram. =
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
fonzie85
Aug 13, 2015 11:50 AM
