Coolant Flush
Car: 1988 Camaro 305TBI Iroc Base
Engine: 305 TBI
Coolant Flush
I have an 88 iroc base with a 305 TBI engine. The car has been sitting for several years and I need to drain all fluids and replace them, but I am not sure as to how to perform the radiator flush. What hoses am I to remove and what liquid do I use to do the flush? Should I use water or buy a special radiator flush liquid? Please help! Thanks!
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Re: Coolant Flush
Just unscrew the clamp it will start to leak but you need to pull it all the way off the radiator to allow it to drain. Tighten her back up after shes done draining and fill with your choice of coolant. I use Peak 50/50 longlife antifreeze. But dont get fooled by the "longlife" printed on the jug.FYI this does NOT get all of your coolant out of your motor, but is the most common procedure for a coolant flush on these engines.
Re: Coolant Flush
Easiest way to get ALL the fluid out (and by ALL I mean EVERY LAST DROP) is to remove the block drain plugs, in addition to draining the radiator. The pass side one is cleverly disguised as the knock sensor. Once you find that, the driver's side one is in the exact same place, except (duh) on the other side.
I don't use the 50/50 anti-freeze; not because there's anything wrong with it, but rather, because 100% AF is like $12 a gallon, but the 50/50 is like $11 a gallon, meaning you're paying $5.50 for a half-gallon of water. I'm pretty dumb and all that, but I'd like to think that I'm smart enough not to fall for that one. Instead I buy the 100% stuff, and then go over to the "water" aisle in the store and spend $0.79 a gallon for distilled water. I NEVER EVER EVER FOR ANY REASON EXCEPT EXTREEEEEEM DESPERATION (sitting by the side of the highway with a burst part) put tap water in my cooling system; distilled water ONLY.
If the car still has AF in it now, prolly doesn't really need a "flush"; just renewing the fluid should be fine. Only needs a "flush" if you see foreign matter of some sort in there. Corrosion, scale buildup, oily gunk, or stuff like that. Otherwise, new coolant will fix it right up.
Re: Coolant Flush
Car: 1986 Trans Am
Re: Coolant Flush
I'm with Sofa, I don't buy the 50/50 stuff. Straight antifreeze and distilled water.
I try and pull the block drains if i can to drain all of it. I usually try and pull the heater hoses off and flush that out with a garden hose also.
If you only drain the rad your probably only changing 2/3 of the coolant at best.
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
Re: Coolant Flush
Chocolate Milk. This is with an old Prestone Flush Kit I have had for a few decades.
