Turn key and right fan comes on
Old Apr 29, 2014 | 09:58 AM
Newfie Iroc's Avatar
Car: 1989 Iroc Z
Engine: 5.7 L98 G92
Took car out of storage and when I turned key to on position the right fan started and stayed running while the car was on...Turned off the key and fan stopped.... What is the cause of this? And how do I fix it..
Old Apr 29, 2014 | 10:34 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Turn key and right fan comes on
Most likely fan switch is jammed on. It's located in the passenger side head. Test by checking for ground on pin on cold engine, if yes, replace the switch.
Old Mar 6, 2015 | 06:42 PM
S2HT Z28's Avatar
Car: 1985 Z28
Engine: 5.0L
Mine does the same thing. Turn the key to the on position without starting the car and the right fan comes on. Mine makes a heck of squealing type noise. I was thinking the fan motor might be no good? Should the fan not come on in with the key in the aux position?
Old Mar 6, 2015 | 07:17 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I'd try unplugging the fan pressure switch on the refrigerant line as well (do separately to pinpoint).
Iirc, 88+ should run both fans if the fan switch (pass. head) kicks to ground (fan switch is tied to a/c fan request switch).
eightsixseven
Dec 16, 2024 01:50 PM
9192camaro
16
Feb 3, 2019 12:21 AM
5spdcamaro
Aug 28, 2015 02:12 AM
Bryan F
Aug 18, 2015 02:28 PM
wayshegoes
Aug 17, 2015 12:00 PM
