temperature?
Old May 17, 2014 | 01:14 PM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
temperature?
hi ive got a 91 305 tbi the car has external gauges on the dash for the water temp oil pressure an volt gauge....well all of them work except the water temp I think....my car has dual electric fans wired up separately to a manual switch an my car has a 160 degree thermo in it...is the thermo the problem or is it the gauge? plus ive deleted the diverter valve bcz I thought that might be why I don't have heat so idk if its the thermo or something else thanks
Old Jun 25, 2014 | 06:01 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Temper Tantrum
With the engine OFF, but the key in the RUN position, ground the sender wire, then look at the temp gage.
What does the gage do when that wire is grounded?
Happy Racing !
When you see fog or “running” lights on in good weather beware. WLow performance driver ahead.
db057
Jan 10, 2020 08:55 PM
ironbmt
Sep 27, 2015 06:00 AM
Logan Bryant
Sep 23, 2015 06:51 AM
BWilcox
Sep 20, 2015 12:19 PM
